okay fire control has become unusable the the couple days. constant freezing, sometimes its when uploading file. sometimes its in the middle of a cut, i have some big jobs coming in cutting t6 aluminum and i cant have this happen. the material is so expensive to have issues while cutting, is there another program i can use that is better? i dont care if i need to pay for it, mach 3 iv heard about but have no experience with. any advice would be great , im using the computer screen that came with the table, all updates have been done and i have the noise cancellation on the usb cord
Which plasma cutter are you using? What version of FireControl?
Where is your plasma cutter in relation the pc? are you using the usb cable with provided and with chokes installed in addition to the usb isolator?
i believe i fixed my issue last night. i did move the plasma farther away but i also had my shop sound system running off the same circuit that the table is on. i moved the speakers to the other side of the shop and my fire control hasnt frozen since. i had no idea it could effect it that bad.
I’ll mark this thread as solved, but keep an eye on it and let me know if it happens again.
