Getting my new XR table up and running. Not sure where to start on this one. I’m running fire control and sheetcam and a razorweld. The torch fire almost instantly as it probes the material even with a delay. my biggest issue is the torch is still firing as it raises at the end of a cut. The start isn’t that big of a deal with the lead in but burns a nice hole at the end of the cut. Not sure where to change the setting to get it to stop firing at the end of the cut. before the torch raises. If I add a delay at the end of the cut the torch still continues to fire for just shy of a second at the end.
look for the 4t2t and switch it on the plasma machine…
Awesome thanks I’ll check it out when I get home tonight.
Thanks solved the issue
