how do i shrink the size of my image in sheetcam to fit on the table size
I did this divided the size i wanted by the size it was came up with .04 hit ok then generate and it did nothing
Was it a metric file you opened up with standard settings?
When you import the file, you have to select the correct units of measure. If the file is metric select metric at import. If you select inches on a metric file, it will be 25.4 x bigger than it should be.
it might seem like nothing but move the torch around after you generate, and you might see the difference.
