I have been doing some signage was some smaller font. How do I go about either doing no lead in on the font and using lead in on all the larger Cuts or a smaller lead in on the font and larger lead in on the larger pots allowing the aero to be on the correct side of the cart for the font?Is it possible to have lead in and no lead in on one post process??
Think you just have to do multiple setups and then make sure they are all selected when you post process
I have successfully accomplished this by creating a new CAM 2D path under the same setup. Be sure to reorder your CAM paths by dragging and dropping in the list on the left. You can make sure it does the small cuts first then onto the larger ones using the simulation action in Fusion.
