Is there a way to cut a sign bigger than a 2’ x 2’ for example if I had a 2’ x 4’ piece of steel and cut the initial section and then moved the steel over to complete the sign cut out. Does this make sense?
It’s called indexing. If you Google that toy should come up with some different options.
Some discussions here as well accessible via the search function.
The CNC router people have been doing this for a long time. But it’s a pain to try to explain in text The founder of Shopbot did a YouTube video that explained & showed how to do it - much clearer than any text write-up.
Certain software can do it .
Called tiling
