Is there a way to make Mach 3 show the dimensions of the files your cutting out. I always forgot to add the dimensions to the file now. Then forget how big each file is when I go to cut it.
in fusion there is a report function that gives you everything you need as a PDF to match with the file. You can make this file the same time you make your .tap
I’ll check that out thanks
