Shipping Container Brackets?
I recently got a 20’ shipping container and want to make it look less like a shipping container. Does anyone have any ideas on brackets that could be cut on a CFP to attach some wood studs and then some lattice or siding? I’m not opposed to welding something onto the top and bottom of the container, that way I wouldn’t penetrate the walls.
This thread has a couple of ideas. What I like about the suggestions on this thread is that you don’t have to be so meticulous to aim for the mounting holes.
You probably have already thought of using construction glue to attach pieces of wood to act like studs on the sides.
Keep in mind, these metal containers need lots of air circulation to limit the moisture that seems to be accumulate inside. Obviously, based on the humidity in your area, this may or may not be a problem. I have come across a number of people with these containers in western Washington state and they all complain of the moisture.
