new and need help please
You can help us all by providing a bit more information about your problem.
What does your pattern look like?
Where did you make/get the design file?
Is it DXF or SVG file?
Can you upload the ‘.job’ file so we can see what’s going on?
its a dxf it’s a gnome i bout a hole set or easy and the drawing looks good I am Shure its operator air and need to start over again
Do you use Voice to Text in your reply? (Hint: Don’t do that)
I’m thinking the operator doesn’t have enough ‘air’ to solve this problem.
Answer my questions or you won’t even get one start.
did you purchase the full version of sheetcam? if not, then you’ll only get about 150 lines of code. enough to cut the f bomb bottle opener.
did it give you an error when you tried to post process it?
