Sheetcam post processor default
Since upgrading to Firecontrol and loading post processor I have to reload from help menu every time I do a new project. The default processor always goes back to Mach 3. Is there any way to set Firecontrol as the default?
Do you save your jobs or only output the PostProcessor results?
Do you modify Options->Machine->PostProcessor?
Finally, is the FireControl post processor saved in your Settings Folder/posts?
was saving post processor in Help >setup wizard. Used options as recommended and will see if it sticks.
Thanks for the help
that was the ticket
