Switched to sheetcam and now my torch wont fire when I cycle a program. (It will fire manually)
Which mach3 choice did u guys choose in the dropdown menu during set up? Thx for any input in advance. B.C.
Stick to it you will get it figured out. And love it.
Did you put a file into sheetcam and generated a g code file. Loaded it into mach 3 and your cutter won’t fire?
Do you see any m03 or m05 code showing in your g code?
Where are you seeing the dropdown box?
I think it’s mach3 plasma… I use mach3 with THC and scriber, I edited it though…
