Sheetcam fault won’t set G code
Having trouble in sheetcam when I go to run post processor. Throws error fault.
“Error: evaluation limit reached”
I’m just learning and cutting out a fish. Nothing to crazy.
Designed in Inkscape and it loads up great with good cut paths.
You don’t have a license file installed. The trial version can only handle about 180 lines of GCode which isn’t much - a box or other fairly simple shape.
If you’ve purchased a license you need to install it (copy it) in the Sheetcam directory. If you haven’t bought one, then you’ll need to do that ($140 from the Langmuir shop on their website).
Oh gotcha, thanks!
you will not regret buying it…
