is sheetcam compatible with mach 3 and the og crossfire?
Sheetcam is compatible with Mach 3 and used with the original CF and the CF Pro. Mach 3 is only compatible with the original CF not the CF Pro. You’ll need FireControl (replaces Mach 3) for the Pro table.
Is there, Or where is the tutorial for the setup of the post processor? From sheet cam to mach3 or to fire Control. I am operating the OG crossfire now but am waiting on the Pro.
Thanks
You wouldn’t use a single post processor if you have two different CrossFire systems. You would launch SheetCam differently for each system so it picks up the correct post processor for the target system.
I have three SheetCam ‘launch’ links on my system, one for original CF, one for my modified (and vastly superior) CF, and one for my Laser Cutter/Engraver. Easy to keep them separate.
Where can I find the post processor files? also in curious, what does your modifies CF look like??
