it appears that the code is being inserted on new cuts, but not in the middle of a cut to facilitate the pause, based on cut time and distance
@pjohannik … if I understand you correctly, that is intended behavior of the suggested function ppChkPauseOnTime()…
I see that now. Sorry this code is all new to me. I thought it would start the counter o. Pen down and then after the time limit it would pause. How could I do this in the middle of long cuts?
I strongly advise against interrupting a cut, the variables are many, within the pp or using Action Points with a Code Snippet. I won’t be able to advise on that approach. There a likely very simple toolpath cases where it may work fine within the pp, none come to mind for me at this moment. I’m just pointing out that it only takes one case to ruin an expensive sheet of metal (of course there’s always welding to fix), if you are looking for a solution that works every time and you don’t have to give the situation further thought.
If you have a cut that you believe will be longer than your duty cycle, you should consider drawing the contour as an open shape, but then that presents other cascaded issues such as sheetcam prevented from automatically flipflopping the kerf outside vs. inside for interior shapes. Or perhaps better, consider cutting the long contour with lower amps, slower feedrate, such that duty cycle is 100%.
in my case I am cutting already a slow rate and at 60 amps for 5/8” plate and the part is still causing to hit duty cycle. Also since I am using 5/8 tabs really do not work for what I need. I have the everlast 82i but it still states that 100% is not truly 100% it is 63 amps for 10 min of run and 4 min of cool down. I was trying to automate the process instead of hitting the pause button in Firecontrol.
You say ‘tabs’. That triggered a thought for me, unless your reference to ‘tabs’ means you can’t use sheetcam’s tab placement feature (I’m not sure why). Assuming its not, some time ago I explored sheetcam ‘tabs’ (menu Mode / ‘Edit tabs’) feature for a similar use case as yours, that is to interrupt a plasma contour cut in a specific toolpath. ‘Tabs’ insert a cutter lift in the toolpath, so in the case of Jet Operation, it’s like an end of cut/toolpath situation, triggering OnPenUp(), motion forward on the toolpath to ‘jump’ the defined tab width, and then triggers OnPenDown() to resume cutting the toolpath. In the case of Jet Operation, ‘tabs’ effectively turn a closed contour toolpath into at least two segments, but without the behavior of an open contour. So define the tab width to be 1/2 of your kerf width and you effectively have an edge start on the resuming cut.
In your case, in order to pause, you’d have to manually press the pause button (assuming there is one) on Firecontrol while the torch is off and lifted. Then resume when ready.
I was too hasty in posting the function ppChkPauseOnTime() in the linked reference, I had ripped it from another of my pps and thought I fixed up the variable initializations and boolean testing correctly, but there are serveral nit errors in that code posted above. Rather than explain all the errors, best to just refer folks to the full pp I have since added it to.
I ran it through moderate testing this morning. Sorry if I confused anyone.
sheetcam can leave partIndex, toolClass, and some other global core variables with stale values from a previous pp run. And custom option ‘booleans’ are not actual boolean data type, rather they are 0 and 1.
I will give tabs a shot
I just tried the tab feature of SheetCam for the purpose of mid-cut pause and the suggestion to use half the Kerf width and manual pause worked perfectly for my project’s lengthy cut in 1/2 in. steel. One has to be quick with the left mouse click and some practice with the torch off definitely helps.
That’s awesome. One thing to try that may help you. Calculate the time you need to pause then add a pause at end of each cut. That could keep you from have to be quick on the draw.
@DKent , glad to hear the ‘tab’ technique worked, albeit that it requires a race to click pause.
@pjohannik et al., I have to apologize for not reading the OP carefully enough weeks ago. There were two- (1) (2) -clear questions I missed…
after some testing w v7.1.40, I found that…
- action points with a ‘Length’ value of zero will ignore the ‘Start code’ snippet, but still respect/use/plant the ‘End code’ snippet into the gcode stream. Consider this a perpetual bug.
- I get the same result with menu selection Tools / ‘Tool table’ , that Code Snippets are not enabled for editing from that dialogue. Consider this a perpetual feature.
As for the OPs original idea to use Action Points for this mid-cut pause, machine or timed, that may be worth reconsidering… . Sorry to have sent everyone down a rat hole with pp automatic pausing, although the concept is viable in many cases, except this case of a single contour cut exceeding the duty cycle.
Here’s a code snippet that is perhaps a starter for a working case of using Action Points.
; begin action point pause
G91 ; relative motion mode
G21 ; metric units
M05 ; torch off
G00 Z25 ; Z up 25mm, less water splash while we wait
M00 ; machine pause, click Resume buttom when ready
; alternate pause for fixed time duration
; G04 P240 ; pause for 4 minutes
G00 Z-20 ; Z down to re-fire torch
M03 ; torch on
G04 P0.7 ; adjust as needed, torch fired in open kerf, not an actual pierce
G01 Z-5 ; Z down to cut height
; G20 ; resume inch units if that is your gcode units choice
G90 ; resume absolute motion mode
; end action point pause
Only issue us the cut that needs to pause is the only cut. That is why needed a way to do a mid cut pause
Thank you, I will try this code as well
When you do the tabs then add a pause after cut. It should do the pause automatically as long as you can determine how long you need. It will help you stop and not miss it.
