not sure if this is related but in the debug window it says
Assert failure in function wxCSConv::wxCSConv (C:\wx-3.0\wxWidgets\src\common\strconv.cpp:2873). invalid encoding value in wxCSConv ctor (“Assert failure”)
It could be a license issue. There are some pirated licenses floating about that won’t work on later versions of SheetCam. If you PM or email me your license serial number I’ll check it for you.
not registered / got a license yet, still using the limited free version to learn on to make sure the workflow works first before purchasing, so not sure if that is the issue I thought it was good for 180 lines
the 7.0.10 was the file downloaded recently directly from sheetcams site. But fortunately I found a very old version in my downloads folder I had downloaded when I first bought my machine. version 6.1.47 maybe
As above, I tried everything to get the new version to output something but could not get it to work, the old version was seamless.
The only problem I could find was the error logs listed above, I’ll prob stick with this version and try again once there is an update.
