Is there a way to create a releif cut in a single bend?
Ive looked through the sheet metal rule options with no success.
For example I’m trying to bend a 90* flange on 1/4 inch plate. A releif cut is needed so it doesn’t stress my metal break.
I drew the lines in manually by unfolding and extruding a small rectangle and got the project complete, just curious if this is possible. Thanks!
          In that live stream I did earlier I was literally wishing the same thing lol. And it would also be nice if it could base it after a bending tonnage maximum that you wanted to inform the length of the slot.
There may be an add-on or plug-in for such a thing?
