Setting up plasma cutter
I’m setting up my library for tooling the plasma cutter and it wants to know the nozzle clearance diameter. Could you may be post a pic or diagram showing exactly what we should measure.
The nozzle clearance diameter is a parameter that is used for establishing rapid moves between cuts that avoid possible tip-ups. Below is what i use for our Razorweld torches.
thank you, thats what i needed.
