Well for the most part it turned out pretty good, however I had to do some post cut processing because my ground clamp wasn’t on my material all that well and I think I was running my air pressure too low.
If you do watch the video you’ll notice that at one point the cutting stops and I attribute that to the two points I just made.
All in all lots of piercings on this one, and I learned an immense amount on how to use Fusion 360 and gravit for svg sketches.
30 gallon is smallish…I have a 20 single stage dual head…but I have a 60 gallon reserve before the plasma…works great…but I still hit pause now and then to clean a bit and give the compressor a chance to catch up
Basically just hit pause in between cuts. there should be a setting in the post processing part in fusion to add pauses. Can’t tell you where since i don’t use fusion but sheetcam has a setting to pause after every cut. you can set the amount of time you want it to pause.
when the machine is traveling between cuts…in other words…if finishes one cut then start to move to the next cut you just pause FireConrtrol with the screen button…wait a while then “resume”…
Sounds like a solid learning experience! Post-cut cleanup is pretty common, especially when dealing with grounding issues or air pressure settings. It’s great that you’re paying attention to those details—they really make a difference in the final cut quality. Fusion 360 and Gravit are powerful tools, and mastering them for SVG sketches will definitely open up more possibilities for your projects. Keep experimenting and sharing your progress!
