Running 2 plasmas on XR
I have a older Hypertherm 45 and from time to time I have the need to cut 5/8 up to 1". Was thinking I could pick up an Everlast 82i and run it through the wire trough and just swap the torches and wiring to the power supply when needed. Little bit of a hassle but doesn’t sound unreasonable. Anyone done this or have thoughts on the topic? Things to look out for? Thanks…
I run two plasmas but fortunate enough that I can use the same torch. I run the PowerMax 85 the majority of the time and then sometimes I’ll run my 45 XP that I can use Marking consumables.
A custom torch Mount that took two barrels would be interesting. As long as you can make sure that they’re exactly the same height.
I had not thought about the custom torch mount idea. That would make the swap much quicker.
