Run from not working in Visualizer
When trying to select a line or rapid to run from visualizer it is not letting me click on any lines. I can zoom and move around. Now if I go click in the GCode, it will give me the option to run from line or loop. Just not from within the visualizer. Called Langmuir and their tech said it was probably a control board issue. I replaced the control board with the replacement and same issue. I Uninstalled, and removed the app data firecontrol folder, and reinstalled. Still not working, no matter which file I load. Has anybody else ran into this
I am in the exact same situation.
I even tried to install an earlier version of fire control and still nothing.
I’ve read when others have had this issue everything worked fine when they used a different computer. But I don’t really wanna have to buy a new laptop when it runs everything 100% fine. Weird bug that few people are experiencing . So for now stuck scrolling through gcode.
Same boat. Was working, got new control box. not working. Anything from the team?
EDIT— OK, I broke out my old ancient laptop, ( the one that wouldn’t toggle Jog mode and had insufficient graphics). Lo and behold! The Run From in visualizer works.
So my newer, more powerful HP computer is the problem?
WTF guys?
I even reinstalled windows. Still did not fix it. Used a differant computer and it works
That’s pretty crazy your older laptop does not have that problem. So that makes it seem some file is corrupted. And that they could fix the issue? @langmuirsystems Lets get a fix please!
