Run From Here doesn't exist in G-Code Window
Running a piece, and was about 790 lines in when movement stopped, but the torch kept firing. Hit the stop, and the torch shut off. Had to unload the XR from FireControl, shut the XR down, and then reload in order to clear the XR. Reloaded the g-code file, and scrolled to the line I think it crashed on. The orange button on that line says Run from Loop, but it does nothing. A few lines above and below that one, the Orange Button adds an option - now has an orange Run From Loop or Run From Line - still neither button will do anything. I’ve scrolled 40-50 lines above and below, and never get the Run From Here button. FireControl is running version 21.5, so it is def after that button was released.
I have no doubt it’s something simple, and is an issue with the keyboard to seat interface. Any help or ideas? Thanks!
This might be helpful….
When you’re in firecontrol if you get a part that don’t cut or have an issue and it stops in the middle like error you can have it start wherever by going to the lead-in for part you’re trying to cut and highlighted it and hitting the orange line button. It will ask if you want to generate cut path from that spot and say yes. The one thing you have to do is start from the original work zero spot. If you don’t it starts from the wrong position. hopefully this helps with future errors.
1
This post also walks through the idea on restarting your cut
Appreciate the quick answers!
However, when I try to select either Loop or Line, nothing happens. XR is in the work home position, and everything else looks normal.
Does it have anything to do with having had to exit out of FireControl / shut down the XR in order to clear the machine having stopped moving? I’ve tried hitting pause and stop both when it happens, but neither do anything, so the only way i can clear everything and get control of the machine again is to completely exit the software, shut down the XR, and then restart / reload everything.
i guess is you’ll have to get out of FireControl and go back in it. When you load your design it should go back to same starting point (blue button). You’ll want to check this by moving around in fireControl and checking couple points on the design. then hit blue button again and select lead-in point and regenerate cut path. Don’t hit “zero all axes” or that will create new starting point. I wouldn’t restart computer myself unless getting out of fireControl don’t resolve it.
Thanks, Don. Actually have done this, and the problem is FireControl never brings up the box to regenerate the cut path - the line in G-Code has the orange boxes available to run from line and run from loop, but pressing them does nothing. I’ve even tried the process from a slew of other G-code lines, and none of them will advance to the regenerate cut process.
I’ve reached out to Langmuir support. Cameron was puzzled by this issue as well. We are going to schedule a time for him to log in to my system and run through it himself. I’ll post results once we find a time that works. Appreciate the help so far - hopefully we’ll get it figured out.
I am currently having the exact same issue and dont want to take the steel out until my cut is finished. what was the solution to this issue?
I would image it would involve an uninstall and reinstall. But you’ll lose your zero. UNLESS… you have limit switches and you had honed your table prior to the program.
just uninstall and reinstalled still no difference only have the line and loop buttons that dont do anything
Interesting. I used my button today and it popped up the generate box and worked….
Has it worked for you before?
What are the specs of your computer?
it worked a while ago but not sure why not now
Sorry man, I’ve got nothing. Too bad the OP never updated.
thanks anyways, just a bummer, probs wasted a 1/3 of a sheet of 5mm
Well…. You could edit the code manually if you need to salvage it.
Sorry all - life got in the way, and I had forgotten about trying to get with Cam on this. Until tonight…
I’ve run dozens of files since the original post, and the rare times I had a cut fail, I just rebuilt the drawing / g-code to remove everything that had already cut. The cut that failed tonight was too big and complicated to do that, so I tried again to restart in the middle of the g-code. Still getting the “Run from Loop” option, but when clicking (and double clicking) on it, the subsequent start / Run from dialog box never pops up. Searching the Forum hasn’t turned up any help for this problem - all I can find are very well written instructions for how to start from a point, but mine won’t bring up the next step once I’ve selected the line / loop. Thought maybe it was a touch screen issue (using the touch screen PC that Langmuir supplied with my XR), so I tried a true mouse - no change in result. Verified that I am running the latest version of FireControl (21.1.5). Hate to lose 1/3 sheet of 3mm, so hoping someone has run across a solution by now. Thanks!
Once you pick the line in the visualizer, try “Go to Work Zero” and see if that the “Start” option lights up.
(Note: I see I am 11 hours past your original post so you might be past “helping” with this information.)
Tried that just now - didn’t do anything. Even tried having the torch in different locations - at work zero, in the middle of the sheet, etc - before selecting the line to run from and hitting go to work zero. Appreciate the response, tho!
