This my first time trying to rotate a part in fire control.
XR table
So I had a part the I was going to cut out of a full sheet and decided I wanted to rotate it 90 degrees for less waste. When I did the origin did not move with it, and I guess it cant,
Would have been ok if it had rotated on the point the origin was on but it moved the part several inches from it. Not sure if this makes sense or not. might have to try it to see what I mean.
You can manually change the origin point in FireControl using the “Set Program Origin” function. This will create 5 options - one on each corner & one in the middle. Select the green box where you want the origin point to be and you’ll be good to go.
