I believe i saw something about this but cant find it now. Is there a way to back a program up abd restart from line mid program? I had a skip cut, knew what line would have cut it but couldn’t figure out how to start there.
Thanks.
Yes,
I am away from my machine or I would screen shot it. It is in the lower part of the screen in fire control. It gives two options run from line and from loop.
If you choose from line it starts at the first of the line you select. It will not lead in.
Check out this old topic
Just click on the spot in the visualizer and it will give you the option to run from line or loop. Choose line and it will generate a new program to cut from that point forward.
Awesome. Thank you for the tip. I much appreciate it.
