You sent the g-code. Although it may have information that is helpful, he won’t be able to correct your drawing from it.
TinWhisperer is looking for either your DXF file or preferably the file that Fusion exports (xxx.f3d).
Here is where you create that file:
Then it opens this dialog:
I actually believe that given enough time @TinWhisperer could take all of our g-code files and recreate the drawing. Sounds like an interesting contest. But…he might have a reversed engineered g-code compiler: that would not be surprising.
Ok Thank You. I wasn’t entirely sure what he needed but thanks for the clarification. I’ll get uploaded asap so hopefully I can get this straightened out.
For future reference and to help people understand your problem correctly, the THC is the computer chip. The thing that moves the torch up and down is the Z axis.
As much as I think I know about Fusion 360, I keep finding out I really don’t know that much. My issue that is perplexing me is simply making my simulations more visible. I have tried to apply appearances to bodies but that seems lost during the simulation of the CAM. (I get lost in the menu options)
You videos and the simulations are always so easy to view. What am I doing wrong?
The example I am giving did not actually use “bodies.” Here is a screen shot of Manufacturing and it is the “Rings” tool path that I am currently working on. They will be cut out of 1/4 steel. The CAM process is pretty straight forward as I have put each ring on a separate projected sketch.
We’re beginning the computer and software setup on our Crossfire XR. We already setup a user name and password. But now that we cam back the next day to finish the setup, the computer won’t recognize the password. Is there a tutorial on how to reset the computer and start over?
