Has anybody had this problem?
I updated fusion 360 and now my local tool library is empty when doing a new set up in selecting the machine. When I go manage, tool library tool my saved tool are there.
Any help would be appreciated
Fusion 360 Lost Tools After Update
If you’ve lost your tools in Fusion 360 after an update, it might be due to the update process or changes in the software interface. The “Tools” tab has been renamed to “Utilities” in the January 2022 update, so check if the functionality is now under this new tab.2
If your tools are still missing, you can try the following steps:
If you have updated to the latest version of Fusion 360 and the issue persists, you may need to manually import the tool library files. Download the library file (.tools or .json) from the cloud, then use the Tool Library Manager to import it into Fusion 360.
Here is another good link to check out:
