Razorweld losing arc when head lifts
Don’t know if this might be something to help you out but @S_Oates came up with a little program for easily adding pauses to cut files.
Adding pauses to g-code files
I’ve used it on some pieces with lots of cuts (my compressor isn’t super big) and it works well. Does .tap or .nc files. You just specify the pause length (and also you can add pauses every X cuts for torch cooldown if you like) and it inserts the code and saves out a modified post.
Pretty nifty.
