Razorweld Cut45 - 12 Gauge Hot Rolled Mild Steel Cut Parameters?
I’m setting up a new tool in Sheetcam for 12 gauge hot rolled mild steel and am wondering what the best parameters might be for a clean cut. I’m using a Razorweld Cut45 with a machine torch.
Amps?
Peirce Delay?
IPM?
Kerf Width (0.8mm tip)?
Cut Height?
Any additional help or information would be greatly appreciated!
35amp .2 delay and run about 120 ipm, should get you close and you may be able to do 150 ipm
