Razorweld 45 consumables
I use my machine for ductwork fabrication. Is there a fine cut consumable for the razor weld 45? We never cut thicker than 22ga galv.
Welcome to the forum! I’ve moved your thread to the Plasma Cutter category so it’s more focused to people who will help you.
Yes there are fine cut consumables, ebay number 186038278934
I’m sure you’re aware of the Zinc/Oxide gas produced when cutting galvanized metal with a plasma or welder. Ensure you wear a rated mask. Well-ventilated area. It is carcinogenic. Then again, everything in California is a carcinogenic prop 65.
Just my two cents.
Welcome to The forum. Are you doing HVAC work?
Good old zinc oxide poisoning(metal fume fever). Gross stuff.
Here’s a post I made about that topic with a linked piece of pretty informative literature.
