I purchased the Razorweld 45XP through Langmuir with the CPC port. The Razorweld operating manual depicts the divider port on the left and the Torch on/off on the right. However, the CPC cables that came with the torch from Razorweld, has instructions that say just the opposite. Which documentation is correct?
I think, if you search this forum, you’ll find MANY posts on this subject. Net: is the documentation is meaningless. RW seems to be very arbitrary on which port gets connected to which connector.
The good news is that you won’t break anything if you miswire it. Hook it up one way, try to fire the torch. If it works, great, if not, swap…
Thanks TomWS. I did search. Your answer that it doesn’t hurt anything if you get it wrong was just what I needed.
Thanks doodz. I had the same issue. Swapped connections and it fired.
