Razorweld 45 cnc machine torch info
Are you sure you jumped the correct signals?
Did you try to manually move the electrode? Maybe it is stuck. How is the torch mounted? Clamping it on the lower portion of the torch will bind the movement and could wreck your torch.
See Machine torch mount causing beveled cuts and how to fix it - #5 by mechanic416
