Razorweld 45 CNC Cut Speed Incongruencies
Hello all! New to the forum, from Central PA. Also new to CNC plasma cutting. I just have a question for those of you familiar with the Cut 45 CNC. Is there a torch set-up guide available for download? I thought I had the right one, but the Recommended Cut Speed IPM for 14 gauge mild steel at 45 amps is 280….I tried that and NOPE. Lots of missed areas, poor quality cut. When I slowed down to around 160, the cut seemed pretty good with very little dross. I’m running a Kobalt 80 gal compressor providing a solid 170 running through a new air filter and desiccant dryer to the PC. I observed the gauge on the PC at around 70 during the cut.
Do I have the right guide? I’ll be doing some test cuts in the next day or so to get my new XR w/THC dialed in. But it would help to have a reference to start with….
Also, do they make fine cut consumables for the UBHY45-25M machine torch? I’m already seeing the limitations on the Cut 45 CNC regarding letter spacing on personal monograms.
Thanks!
