Hello my name is Todd I am new I am trying to cut a sign. But the torch stops firing when it’s cutting a letter then it goes to the next letter and fires again and then stops in the middle of that. I have plenty of air I’ve checked all my connections if I do a dry run it works fine. Has anyone else had this problem?
It may be the speed is set to low. Try and up the speed some and try that.
Ok, thank you.
