(Took the outlet apart and put it back together and it works. Don’t know what I did wrong before, but it’s working. Thank you)
Brand new razorweld 45, went to power it up today and nothing is happening. It’s connected to a 50 amp double circuit breaker. I tried turning it off and on. With and without air hooked up, both the torch and the ground wires are attached to the machine. I can’t figure out why it’s not powering up at all. I tried emailing razorweld also, I just figured someone on here might have an idea what’s wrong. Thank you
