It would be awesome if someone currently using the Razorweld cut 45 could share their tool setup parameters in Fusion 360.
Thanks in advance!
I followed Langmuir’s tool setup they showed in the F360 tool setup video. Working fine so far.
Thanks! I watched the videos, but was making sure there was not any significant difference in the setup for the razerweld vipercut 30 and the cut 45.
Thanks again for the info.
It’s working okay for my Razorweld 45.
I haven’t run any kerf tests to see if those are the same but with the same nozzle & power it ought to be.
I am a woodwork by trade and run a water cooled CNC system for wood. The software systems are similar but a whole new world for me with the plasma cutter. It looks like I am a long way out in receiving my crosscut system, so I’m trying to get a head start on all the quirks.
All the tips and tricks I can find are great!
Thanks again!
I teach CNC machine operations for a local Makerspace - laser, router (wood) and water cooled metal. I also have a laser (Glowforge Pro) at home. I like the ability to use the same design software and even the same files. I do have to watch out for the thickness of the material I leave behind - what works in wood or plastic may not be sturdy enough in thinner metals.
The Shopbot can start with same or similar designs but with variable Z-axis cutting it’s more 2.5D than the flat panel stuff for the laser or plasma cutter.
