The internet is undecided if the torch height needs to be increased when cutting aluminum…so I’m asking the crowd here.
I did my 1st cuts on the Crossfire (w/ THC) this weekend and after some trial and error, yielded some good parts. I was cutting 1/8" stainless (45 amps @ 40 IPM using a Razorweld Cut45), and had the torch height set to the default .063".
I developed a small (2"x3") test cut and and samples from 55 down to 30 IPM…and found that 40 seemed to give the better results.
My next efforts will be cutting 1/8" 6061 aluminum. I plan on running more of the 2"x3" test cuts to dial in the speed, but should I plan on changing the pierce and torch heights?
