So, I have the IHS/THC on my CF. Where/how are you supposed to clamp the machine torch in relationship to where once the IHS triggers, it moves to some preset ht.
I used the “Straight Line” cut feature in Fire Control with the use IHS ticked. So, it goes down and touches off, and I was “Assuming…” that it would then jog the Z to some kind of internally hard-coded Pierce ht. then move down to cut ht. So after touch-off, my torch is turning on about 1/2” above the metal and starts moving. So, I guess my question is, does anyone know what the internal (in Fire Control) the pierce ht is (if perchance you may have measured it, or know it somehow)?
