The symbol between the connection is the load. Sensors can be positive switching or negative switching (NPN or PNP) so if the sensor is wired to a relay the relay is going to need a negative from the sensor or a positive to make it change state. If you have it backward the relay won’t do anything because both side of the relay coil will be the same.
