This issue has been brought up a few times in the past.
If the majority of your program speed is not the standard feed rate issues will happen.
If you have a path that has most of the feed rate is optimized then change the standard feed rate to the optimized one for that path, instead of using optimization. or combined multi paths into your NC file.
