So im at the point with adjusting these. I guess i stripped out the main screws on one. From what i read i was to tighten them and back them off and now the bolt just spins… im talking about the 2 cap heads and not the set screw on the top
Help
Help
Hey Yoda!
Sorry to hear you’re having a bit of trouble. It’s definitely not going to be completely uniform or perfect.
The most important factor is just getting it to roll smoothly. Not all bearings will make contact simultaneously. I agree it is one of the more involved assembly steps. As far as the stripped component though, give us a call on the support line or an email at [email protected] so we can cover you under warranty if you’re within the window, or if you’re outside of warranty we can get you setup with an affordable replacement component!
