Print in Drwg Env. Sorry, only have a minute.
Thanks Bret.
I can also confirm, I print from the drawing environment quite often.
They did end up actually having to cut some of these rings out of 14 gauge stainless.
The ugly looking one is the original shim I took the measurements from
If you divide your hole diameter by four and use that is your lead in radius it’s almost a perfect center start.
