Okay team I am stumped!
Equipment I am running, crossfire pro and second gen Primeweld cut 60. I have had no issues to date and I am running using the cnc port divided voltage, (I know risky) Here is where the issue comes in, I cant get the machine torch to work. I bought a used machine torch (primeweld) and it worked but not good went through consumables super fast so went back to and torch. Then bought the new Primeweld coax machine torch and it wont work. Fire control runs just like the system is working I see live voltage the air comes on and the table runs through the program with no errors the torch just never fires.
Thanks a bunch George you are still the guru! Bumped the air up from 55 to 65 and the machine torch worked flawless!! Who new a few psi could make all the difference.
I could not find anything that told me to run an extra 5 psi for the machine torch that would have been some key info up front.
