I am wanting to trouble shoot my machine some. If someone has this machine and a crossfire pro and would like to help, I would like someone to send me a small file to cut out of 1/4 material. You tell me the settings for my machine and then compare the two cuts.
The reason I am asking for this is because to get mine to cut 1/4 steel, I have to run the settings close to what it would take at 1/2 inch steel. If someone else with the same setup and same code can cut it and mine doesn’t, then I can verify its not the programing and either something in the THC or the PrimeWeld machine itself. If it cuts like it should then its user error in the programing somewhere.
