I just got a new Primeweld Cut 60 with the hand torch. The torch came with a stand off installed. Should I take it off to do CNC cutting? Seems like i wouldn’t be able to adjust the cut height otherwise
New to CNC plasma cutting
Welcome to the forum! Yes, remove the spacer, it’s only needed when hand cutting and, as you have observed, will interfere with CNC operation.
