I followed the directions for wiring the torch to the inside of the machine (like in the pic). Do I need to remove from inside the machine and solder to the CNC pins in the back? Thanks
Instructions: Locate the torch firing cable that was provided with your machine and connect the blade connectors to the T-Tap connectors.
It does not matter which blade connector gets plugged into which T-tap connector. The polarity and wire coloring is not important.
