I wired up my 45xp this weekend and can’t get it to auto fire when running a program. I tapped into the orange and violet wires like is pictured in the how to threads. I can manually fire the torch with mach3 but it won’t autofire when running a program. Also when I’m running a program I can manually fire the torch and it will cut the part and shut off at the end of the program but not during the program. As in it will cut a hole in the center of the part and just keep firing as it goes across the part to cut the outside diameter. I’m using fusion to draw the parts then saving as a dxf importing into sheetcam to get cut path then using mach for the program running,
Try using fusion to post process and see how that works.Then load that into mach 3.
Ended up haveing just mach 3 selected in post process instead of the required mach 3 plasma.
