BTW, if you put a rotating hook in your booth & hang the parts from that it makes it easier to get full consistent coverage. I also have a similar hook in the ceiling of my oven so I don’t have to jostle things more than absolutely necessary.
You should really strip the piece and re shoot it if you have already fully baked the part. Powders have a set time and temp that they should be baked out. Typically powder manufacturers do give you some leeway but by baking a color multiple times, it can cause defects such as delamination. I can’t tell you how many pieces I have chemical stripped, outgassed, re sand blasted just because of improper adhesion
Also if you are doing multiple coats such as a color then a clear top, don’t fully cure the base coat. I typically shoot the color, once it gets to 300°, I remove the part, let it cool to about 175*, shoot the top coat, then bake at what ever temp and time the top coat calls for. Only time you fully cure the base coat, is if your shooting a chrome base
Correct! If it’s just a single coat your shooting, fully cure it. And I just use a aircraft paint stripper. You can buy it from Auto zone. Make sure your wear proper ppe when applying it. It will burn the crap out of your skin. Once stripped I recommend degreasing with simple green, out gassing then sand blast and reshoot
Well I tried to scuff the one that didn’t come out so great yesterday and it didn’t come out so great today. On the other hand I did my first Yeti type tumbler today. I’m super impressed with the powder coating and how professional it looks when it’s done.
I made my own stands. It’s a variation of different ones I saw on the Internet. Used the CNC to cut out several metal discs to place on a 3/8” threaded rod. Actually came out pretty good. I don’t see myself doing many tumblers but my wife wanted a couple of them done for Christmas gifts.
The only thing that’s a pain is that when you switch powder colors you have to clean the gun out. Not too much of a headache but just a time killer. I guess you’d have to do the same with spray/air paint as well if you used a gun.
I haven’t found a paint stripper that will take the powder coat off. That was going to be my next question. Also, where is a good place to buy powder? From what I’m seeing it’s about $10-18/pound bagged. I bought some to start out with around that price range. This place I bought it from had it to me in three days.
What are you guys doing as far as cleaning your gun out between colors?
I just use “air craft stripper” from Auto zone to strip powder. Typically I turn my regulator to 60 psi, disassemble the tip assembly and blow everything out. Then hook the hose to the gun and squeeze the trigger a few times. As far as where to get powder, I typically buy from prismatic powders or the powder coat store.
