I got the Crossfire and razorweld cut 45. Im cutting 16GA@114 speed, 28 A. The plasma doesn’t stop cutting when moving from location to location. Can someone explain where in is the setup that causes this to happen. see image.
does the plasma cutter have a 2T and 4T selector on the front? if so, it needs to be on 2T.
it does, its on 4T. thanks. I will give it a try
It’s the 2T issue. Pretty common here. You’ll be all fixed when you switch it to 2T
Changing to 2T did the job. Thanks for info.
I bet a good third of the RW folks did that at least once The original one didn’t have the best instruction manual or clarity about the console buttons. It’s a quick fix though so an easy problem to fix.
