I went to use my table, and my torch wont fire. Fire Control says pierce delay is too short. It was set at 0.5 seconds .I tried increasing to 0.75 and then1.0 and still not firing. Could sure use some help with this. Thanks, Jeff
You need to troubleshoot more, and tell us what you’ve done so far.
Remember, the plasma cutter works independently from that of the table.
Naturally, if it won’t fire, why not troubleshoot the plasma cutter by itself. Then go from there.
Let’s see… WHAT Table? WHAT Plasma Cutter? A snippet (the first 20-30 lines) of GCode would clue us in on what FireControl might be complaining about…
Is the torch on/off cable plugged in and not damaged?
Do you have a hand torch that you can use to see if the plasma cutter fires?
Is your air hooked up and set to the correct pressure?
