I have a viper pro 30i cutter. The dry run works smoothly but when I turn on nozzle moves to its first position to cut, it triggers the plasma but stops there without cutting but still on and doesn’t turn off unless I cut the power to the plasma unit.
It used to work properly. opened up the plasma cover and checked the trigger wires and they are ok.
