Im new the CNC world. I am trying to make a part and the software completes the entire operation, but it cuts on the rapid movement lines as well. Its strange because the cutter doesn’t cut the closest rapid movement, but cuts the longest movement. Any advice?
Verify your cutter is in 2T mode
Thank you so much. Part came out great
@Static Welcome to the Forum.
Once you make a few more posts should then be able to post pictures of your project, which I’m sure we d like to see.
