Pierce on a point?
What is the trick to pierce on a point to create the smallest possible hole ? If I create points in the cad can sheet am just move to the point, pierce it at some duration and use a drill to make it the correct size.
I believe if you do search for this you will find that sheet cam has a setting for that exact thing
It is often referred to as pecking but BrownFox explains it very well here:
I found some videos on YouTube I’ll give it a try
The complete SheetCam setup can be found here:
the pecking feature is great once you get the hang of it…
I used it to build my HouseMade 2x72 belt grinder from @HouseWork …
this guy knows how to design and build grinders…
Can this be done in Fusion as well? Often wondered. Are the holes then drillable with a HSS drill, or too hard to drill with the slag/dross/oxides?
remember the peck process is not a hole…it is a little tiny divot a little bigger than a punch set on a metal surface…
drilling it is the same as when drilling a punch mark…there is no difference in drilling
There are several predominant ways but they are all work-arounds.
You can run a separate post processor that only pierces the holes:
Or you can set all of your holes basically to the size of your kerf width (+0.01), run a separate tool path selecting all of the holes and turn your amperage down on the cutter to peck or leave the amperage up to pierce. In this tool path use center compensation, and with NO lead-in/lead-out/finishing overlap/pierce clearance. (Note: You can alter your tolerance so you can use your actual kerf width as the hole size.)
I have it working well. Thanks for the tips. I use sheet cam and highly recommend it. I use fusion daily for some things but I like SC for generating gcode from dxf.
